204 code, machine won't operate
My lift is at a standstill and giving me a 204 "NO HOOD SWITCHES INPUT" message. I checked the switch on the hood latch and it seems fine. Not sure where the hood switch wires go to check the other end.
There is another switch at the front edge of the hood that seems to operate fine when tested, but doesn't get activated when the hood is closed. When I do operate it I get a "no seat switch detected" message. I suspect the wires were reversed to bypass it.
Any guidance is appreciated!
  • Posted 14 Jul 2020 02:25
  • By Dave_Chvilicek
  • joined 14 Jul'20 - 2 messages
  • Wisconsin, United States
Thanks for the reply. You were absolutely correct! The hood hinge bolts were loose so switch didn't line up.
  • Posted 22 Jul 2020 00:35
  • By Dave_Chvilicek
Adjust or repair the switch so that it does make when the hood is closed. You get the "no seat switch detected" because nobody is sitting on the seat. (either that or you've got another problem switch in the seat)
  • Posted 17 Jul 2020 02:59
  • By lumberjack
  • joined 27 Jul'07 - 183 messages
  • Maryland, United States
Terberg YT220
Toyota 3FD100
Terberg YT220
Toyota 3FD100
