W18 Pallet truck cuts out on lift
We have a Toyota W18 Electric pallet truck that performs all functions fine appart from it cuts out on lift (As in the machine instantly powers off with a very very short lift manouvre i.e. 1mm). It will drive fine and was functioning correctly until recently. All battery cells check out good all over the 2v mark and has a full charge. Anyone shead any light on what may be causing it to do this or where to start investigating.
  • Posted 19 May 2020 20:33
  • By robmac33
  • joined 19 May'20 - 2 messages
Thanks Rob
Check the main contactor. If you can, open it up and clean it with compressed air, dust gets inside and causes a bad contact.
Bad connections on the battery can also be the cause this problem.
  • Posted 20 May 2020 01:33
  • By NickHere
  • joined 20 May'20 - 1 message
  • Estonia
Toyota 02-8FD25
Nagano NUZ090D
