Reach is becomes tilt but only at certain lift heights
My selector lights cycle/light correctly for lift, reach and tilt. However at certain lift heights when reach is selected (the lights are correct) I instead get tilt. If I move the forks up or down a couple of inches(or more) the reach feature will work correctly. The handle wiring seems good or else the lights would not cycle, correct? Any ideas?
  • Posted 16 Aug 2019 06:51
  • By kevin_kurland
  • joined 16 Aug'19 - 19 messages
  • New Hampshire, United States
Solved: Finally dug into the issue and found an intermittent open for the wire that controls the SVC solenoid. When working correctly the solenoid should get about 10VDC. When not working it would get zero yet the output at the control card was 10VDC. Checking continuity during the error showed zero also. I replaced the entire run of 3 conductor cable ($40 on amazon) and it works 100% now.
  • Posted 28 Sep 2021 02:06
  • By kevin_kurland
Thanks! I guess I'll be ringing out my wiring harness this weekend!
  • Posted 17 Aug 2019 01:24
  • By kevin_kurland
the auxillary functions are controlled by a separate function control board that deals with the display lights, the selector lights will still show whatever function you select even if you are having a problem out on the mast or attachment. The actual function control is done with a separate function distribution board. Or at least that is the way crown used to do it, i'm sure the design hasn't change a whole lot since then.
The most likely scenario is what brewski suggested, check you mast control cable and any other harness's out on the mast and reach mechanism, i'm sure you will find damaged wires in the reach mechanism or shorted wires in the cable.
  • Posted 16 Aug 2019 23:26
Sounds like shorted/ broken wires in the mast cable.
  • Posted 16 Aug 2019 07:16
  • By BREWSKI
BREWSKI
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
UN Forklift FGL18T
SMV (Konecranes) 33-1200C
