CODE - 1:516
Machine started out coding 2:582 every time they ran over a bump/crack in the floor. Then died and now when you attempt to start up it thinks for 20 seconds and immediately displays 1:516. Error log is completely empty, and hour meter shows zero hours.
  • Posted 5 Mar 2019 01:26
  • By UncleSi
  • joined 12 Feb'13 - 135 messages
  • Manitoba, Canada
Crisis averted... swapped out the Logic Box IPM with a known good one and all is good.
  • Posted 5 Mar 2019 08:19
  • By UncleSi
  • Manitoba, Canada
Punch in operator access code - 20 second delay - Display then shows stop sign with line through it - code 1:516? Can Key does nothing - truck won't start up or do anything Can Key or Normal. Manual says to check CAN circuits ??? Not sure what that means exactly?
  • Posted 5 Mar 2019 05:54
  • By UncleSi
  • Manitoba, Canada
