replaced vaporizer, no real power forward or reverse
had an error code for vaporizer. replaced vaporizer, cleaned carb parts, idles and revs fine (even lifts) but has very little power going forward and reverse. ran fine prior to throwing code which happened while in use, then it was like it went to limp mode.
have coil packs over glow plugs?, all parts on carb seem to be electronically controlled (no adjustment screws and such that I can find)
any advice? having a tough time finding someone to come look at it.
thanks
model variation # MCP1F2A25LV
chassis # CP1F2-9P4607
serial # F810485
  • Posted 2 Oct 2018 01:37
  • By vapidorg
  • joined 28 Sep'18 - 2 messages
This is often related to the transmission, test disconnect the temperature sensor of the transmission and then the speed sensor. But you must be more explicit with the code
  • Posted 18 Jan 2019 11:52
  • By delga76
  • joined 20 Oct'16 - 22 messages
Taylor X550M
Terberg RT223
Esie Cortez Esie Cortez
