tranny fluid like strawberry milkshake
having trouble here,just got older toy fl, been stored inside,when i got it the fluid looked good ,after running awhile the fluid looked like it had water intrusion , changed fluid and it had same result after running a bit,did not drain convertor used dexron 2, did not see any coolant lines from radiator going to tranny...after milkshake colored oil sat a couple days it returned back to original color with minimum amount on surface, no sins of water intrusion , maybe air cavitation, where do i go from here thanks bob i could load pics but dont see a link here thanks
  • Posted 1 Apr 2018 09:52
  • By Arkie49
  • joined 1 Apr'18 - 3 messages
  • Arkansas, United States
Bob clark
ok thnx. so it does have cooling lines going to radiator.are they on the bottom as i cant see any thnx
  • Posted 4 Aug 2018 20:24
  • By Arkie49
check radiator
  • Posted 4 Aug 2018 09:08
  • By forkguy
  • joined 25 Jul'17 - 28 messages
got sodetracked on project will give a few more flushes, would putting a heater dip tube in help any thanks
  • Posted 4 Apr 2018 12:35
  • By Arkie49
Most likely it is water. It will take several changes to clear up.
  • Posted 1 Apr 2018 20:40
Michel Denis Michel Denis
