Display turns off goes into self test while driving CODE 5Q
While i drive this lift around and once i hit a a crack that is in the Cement and lift goes into self test and operator diplay turns off for about 2 secs and turns back On and i still have my functions. I tested I23 in the diplay and it show TLV and i tested for any shorts in the wires from Display to LA and checked good. Display to VM and checked good. What can cause this. My battery connector checks good both from the lift and battery. Lift code does not appear on the display i have to go into the log and it show 5Q. Any help Thank you
Lift model number is 740 DR32TT
Serial 740-08-CB11275
  • Posted 15 Sep 2017 01:38
  • Modified 15 Sep 2017 01:41 by poster
  • By israel_p
  • joined 15 Sep'17 - 5 messages
Did you swap the fuse card or just the relays? Problem is female socket in card. The EPO switch has been known to go open intermittently, causing shut down or weird codes. Jumper to test or replace the emergency power switch.
Put he truck up on jacks, engage the throttle to run steady. With motor running and wheel spinning, GENTLY wiggle wires at VM, cards, relay board. VM plugs are bad on 7400's for poor connections in plugs. Seen this on brand new trucks as well. After working on these for 10 years, then working on all other brands now, I realize how poorly designed these Raymond 7400's are.
  • Posted 20 Oct 2017 13:15
  • By EasiTek
Battery has been changed about 4-5 times and all battery's check good. Contactors check good and u- phase cable was replaced new to the TA.
  • Posted 28 Sep 2017 15:50
  • By israel_p
Thoroughly check your battery.
  • Posted 28 Sep 2017 03:19
  • By stam
I checked what you told me and swapped with another lift , lift now stops and shoots code 44. Any help ?
  • Posted 28 Sep 2017 02:18
  • By israel_p
I will keep you posted thank you.
Could that cause a code 44 and 42 and 5Q ?
  • Posted 15 Sep 2017 23:18
  • By israel_p
I have pulled them out and inspected all the joints and reflowed the bad ones I found, new relays and all is well, check the relay sockets as well.
Swapping with another truck will prove if it's the card or not.
  • Posted 15 Sep 2017 21:11
  • By stam
How can I go about testing that?
Swap with another lift ?
  • Posted 15 Sep 2017 15:18
  • By israel_p
Check fuse relay card. Solder joint break/relay problems.
  • Posted 15 Sep 2017 07:07
  • By stam
Taylor TE650S
Terberg RT403
Omaha, NE, United States
ASSET FINANCE
Nov 2025
Taylor TE650S
Terberg RT403
