8BRU18
Fault codes displayed, FD, 43, 59, 61 and 72 after brake suddenly applies while driving, intermittently every few days or so and sometimes only once a week. And less often the dash display will go blank or flicker then once the key switch is cycled works ok.
All wiring and plugs secure, battery new and charged, fuses changed and fuse holder ok.
Any input would be helpful.
  • Posted 19 May 2017 23:50
  • By tom_p
  • Alberta, Canada
For anyone with similar faults or symptoms.
It turns out above issues caused by key switch. When driving over rough floors the plastic Raymond/Toyota switch would fail open occasionally just long enough to shut down.
Internal switch terminals are riveted to screw anchor, and eventually loosened.
  • Posted 24 May 2017 04:29
  • By tom_p
  • Alberta, Canada
Mobicon 2T
Ncn 85TH
Ncn 85TH 2014
