STILL R70-25T
HI ALL I HAVE A STILL R70-25T YEAR 1997 S/NO 70390543 RUNNING ON LPG. MY PROBLEM IS THAT IT WONT,START WHEN IGNITION IS TURNED ON THE LITTLE KEY LIGHT ON PANEL FLASHES WHEN TURNED TO START POSITION NOTHING HAPPENS CONTACTORS DONT EVEN PULL IN.
CHECKED ALL FUSES AND CONNECTIONS.
ANY IDEAS.
  • Posted 3 Apr 2009 18:51
  • Discussion started by simon_a
  • south yorkshire, United Kingdom
hello my trolley still R70-30 has the same problem it starts but does not want to move can you help me thank you
[email address removed]
Vvv
Hi Simon,
R70 type 7039 has no starter motor, the generator is used to start engine. The direction lever must be the centre position, the neutral light must come on before you attempt to start the engine.
The batteries must be in good order, check them both.
Just for a quick test, remove the round monitoring plugs from drive motor and generator and try to start the engine. BUT do attempt to drive machine - make sure the handbrake is applied!!
Good luck
J
  • Posted 10 Apr 2009 22:02
  • Reply by JBrad
  • Lancs, United Kingdom
Hi simon how you getting on with your still starting problem?
  • Posted 9 Apr 2009 06:15
  • Reply by powerlifter
  • united kingdom, United Kingdom
A good engineer is a helpful engineer
its on the main fuse card, relay 9K2 controls engine starter solenoid located on the main fuse holder board behind the left hand front panel if its the one im thinking about.
  • Posted 5 Apr 2009 01:42
HAVE CHECKED DIRECTION LEVER WHERE ABOUTS IS STARTER RELAY LOCATED.
  • Posted 4 Apr 2009 20:42
  • Reply by simon_a
Have you checked starter relay and direction lever
  • Posted 4 Apr 2009 03:17
HDX to launch Korean electric range Jeonbuk-do, Korea, Republic Of
US monthly confidence index rises Washington, DC, United States
Hawker Powersource, Inc.
edition #1231 - 22 May 2025
In this week’s Forkliftaction News we look at HD Hyundai XiteSolution’s plans to be the first Korean company to launch medium and heavy-duty electric forklifts to the market, in a move which shows electrification continues to gain momentum throughout the sector internationally... Continue reading
UN Forklift FB25N1QZ1
UN Forklift FD35T
Your Focus
Marko Tulokas Marko Tulokas
president and CEO, Konecranes
Director, solutions development procurement, Dematic
General manager - sales, FM Logistics India
CEO, Caterpillar Inc
