Hello and Hi to all here,
I have purchased a Still R70-25 2002 forklift and i have a few codes coming up on the dash. I have been reading other posts here and they are very helpful. I have faults 196 and 226 showing and i read that these are relating to brush motors? Is it easy to access the brush motors on this and from where. Also is it possible to get a manual of this maching maybe pdf?
I hope im not asking too much on my first question and i cant wait to see what you can help me with
Regards
John
from the book
224 Short-circuit fan switch
225 Transistor failed or cabling faulty
226 Sustained short-circuit
hello
i have olso error 226 and the cooling fans are not working, when i start the engine they turn for 5cm three times and then the error comes up (226) do you know what is the problem or where to look for what is wrong?
Hi John,
If you can let me know the first 6 digits of the serial no. I will look them up. Check my profile and drop me info by email bud.
They show as a current sensor and fan fault on earlier machine but have different meaning on the ASM models.
Hello
I have also code 61 showing as well, not sure what this refers to?
Thanks
John
