Yale UNKNOWN:
steering issue
We have a Eaton/Yale forklift fitted with a Perkins 203 direct injection engine, cannot find serial number its about 25 yrs old, Eaton on the back weight and Yale on the side covers.
Problem is that the steering has become very heavy, this happened very suddenly and the other hydraulics work ok. Wondering if anyone had any suggestions and it would be very helpful if someone had a diagram of the steering system.
  • Posted 28 Mar 2015 02:26
  • Discussion started by gareth_o
  • chillout, United Kingdom
Hi,
Thanks for the reply, will check out the suggestions. Found the serial number along the right hand side of the engine compartment. The serial is E3000265
Removed the pressure piped from the orbital unit and started up, to check the flow then re-fit. Now appears to be working again. If anyone does have a diagram of the system it would still be appreciated as the issue may well come back
  • Posted 2 Apr 2015 05:56
  • Reply by gareth_o
Hi Gareth, I'm thinking with Eaton on the counterweight it may be a GDP40AB type have a look on the top of the frame were the counterweight is fastend to the unit left side or right side and you may find the serial no stamped into the frame. I would check king pin thrust bearings and it may have needle roller bearings that support the king pins check them the caps can split of them and you can loose the needle rollers. Maybe you could T a pressure gauge into the steering cylinder at the steer cylinder you should be looking for 1500lbs at least have a listen to see if you can here oil being pushed past relief valve. It could be the steering orbit roll has past its sell by date and is partially seized I've had them go like that. If the steer cylinder pickings had worn out the steering would be lighter and steering would be slower to operate.
Regards Nero.
  • Posted 29 Mar 2015 00:07
  • Reply by NER045
Unicarriers FHGE35T5S
SMV (Konecranes) 4531CC5
Johnston, IA, United States
Jefferson, WI, United States
St. Louis, MO, United States
ROYPOW
Your Focus
