hi all, anyone been able to install steds on a windows 7 computer sucesfully?
i have instaled software using admin account and XP compatability and all seems ok until i try to open books.
i then have message that adobe supplied on disc (7.09) has compatability issues with W7 and should be upgraded.
I know from the past that later adobe wont work with STEDS and was always told to just use supplied version.
anyone know if there is a workaround??
thanks
Showing items 1 - 15 of 15 results.
hello
or maybe someone can send me STEDS 8.10 or higher
I really need
Thank you in advance and best regards Krzysztof
oke , maar het kan ook gewoon op een xp pc draaien dan , heb ik nu ook
ik heb 813 maar den virutal
Hi , i have 8.9 but i need newer version of it. Any body have 8.10 or 8.11 for me?
verry straens partsbook no and service books oke ?
ken you sent my you dvd s to test it ?
sent it whit https://www.wetransfer.com/
Hi friend.
I sent you a link. /sova/
Does not work you repair manuals?
Problem is setting in adobe reader.
Steds connects online.
Turn adobe connect online.
A library attached to the HDD.
Me also works under Win 7
But only 32 bit XP Emulation
Good luck
I have already tried this but cant get parts books to work (link viewer) when I register diagnostics the message says success but books wont open.
all workshop manuals open ok
hello jan
you ken instal on windows 7 xp mode
Hi thanks for that, I was already told about VMware but my laptop doesn't support it.
there is a work round for Microsoft virtual machine which works on laptop but I haven't tried to install steds yet using this, I wanted to install direct.
hello friend
steds the program can only install on xp
you can install the program steds within a virtual disk xp
to open the windos 7
a program you use VMware to create a virtual disk
I can help you add me on skype: hyster.brasil
