Linde (& Baker) H16:
Starter ring gear and cam belt
Hi, I have got to do a ring gear on a H16 diesel, s/no- H2X391W00075, year 2008. Anyone know what sort of job it is and what is the best way of going about it?
Also, does anyone know what hours the cam belt has to be changed at?
  • Posted 15 Sep 2009 00:12
  • Discussion started by danny_k
also us new starter, had alot of problemns with rebuilts ,eats flywheels
  • Posted 22 May 2015 11:19
  • Reply by edward_m
Hi danny to change ring gear remove side cover,remove hyd pump assy from transmission,take off all pipes from transmission,remove starter motor,undo the 4 bolts that hold trans to bell housing and lift trans out,its not too heavy and you should be able to remove on your own.
Undo bottom+side engine mountings on bellhousing,support engine and remove bellhousing.
Remove flywheel and fit new ring gear,their is a ring gear/starter modification available from Linde.Then rebuild in reverse order.
The cam belt should be changed at 3000hrs,it is recommended that the belt,idler,adjuster and rollers are replaced at the same time.
Hope this helps
herald.
  • Posted 15 Sep 2009 19:42
  • Reply by Herald
  • lancashire, United Kingdom
St. Louis, MO, United States
Johnston, IA, United States
Jefferson, WI, United States
Crown WP302020
Ncn 85TH
Ncn 85TH 2017
Your Focus
Your Focus
