Linde (& Baker) H20CT/600 391:
Starter Problems
We have several Linde H20CT/600 391, 4,000 lb. forklifts with VW/BEF engines. Can anyone out there tell me if they have similar vehicles and whether they have issues with starters and/or ring gears? Thanks
  • Posted 17 Nov 2009 05:19
  • Discussion started by jerry_d
  • Maine, United States
Showing items 1 - 15 of 16 results.
Since we had our 391's equipped we haven't had anymore problems. The only new concern with this lift is with the batteries blowing up.
  • Posted 15 May 2010 04:05
  • Reply by buzz_b
Hi All,
Linde has a STARTER DELAY KIT P/N170560, that when installed will allow the starter drive to fully engage the ring gear before the starter motor starts to spin the engine over (about a 2 second delay).
As I understand this will greatly reduce ring gear wear and starter failure.
Fits 391,392,393 & 394 diesel and LPG trucks
  • Posted 15 May 2010 03:25
  • Reply by StarTrip55
Here is the number to Equipment Depot in Dallas. They were the ones that came up with the solution for Linde. Bill:214-226-4747.
  • Posted 12 Mar 2010 07:25
  • Reply by buzz_b
Thank you for the response, which I've forwarded to the maintenance supervisor. Perhaps our Linde dealer can assist or provide information on this appraoch.
  • Posted 10 Mar 2010 01:45
  • Reply by jerry_d
Our dealer placed time delays on the starter circuit, they said per Linde. The starter engages a second or two after the key is turned on. This is to prevent the starter hunting during start up.
  • Posted 9 Mar 2010 08:53
  • Reply by buzz_b
The issues continue (replaced another starter last week). We haven't replaced the ring gears, as the cost to do all units is quite high. The suggested modifications are not warranteed by Linde and their quoted cost to make the repairs is more than we are willing to invest. The 4 vehicles are being moved to low-use areas and we now have a collection of rebuilt starters. Thanks
  • Posted 9 Feb 2010 23:21
  • Reply by jerry_d
Jerry;
Have you resolved the starter issues yet?
  • Posted 9 Feb 2010 22:57
  • Reply by duodeluxe
  • United States
duodeluxe
We have eight 391's with less than 1000 hurs and so far we have had 4 starter - ring gear problems. The 350's were so much better. Anyone purchase these to work in dusty areas? How are you preventing the engine compartment from getting dirty?
  • Posted 14 Jan 2010 23:44
  • Reply by buzz_b
Hi their is now a mod for all 39x truck starter motors,If you replace any from 391 upto 394 then a new starter is available with 9 teeth instead of 10.You will also need a fitting kit the first time it is done.All new trucks will have the mods fitted.
Hope this helps you all
cheers
herald.
  • Posted 26 Nov 2009 04:04
  • Reply by Herald
  • lancashire, United Kingdom
Thank you for the response.
  • Posted 18 Nov 2009 08:23
  • Reply by jerry_d
Not sure if they are,If the ring gear fails within the standard warrant time/hours think it will be covered if not then you should ask your dealer the question..
herald
  • Posted 18 Nov 2009 08:08
  • Reply by Herald
With the similar problems that others are having, has Linde offered to correct the ring gear under warranty? Thanks
  • Posted 18 Nov 2009 05:18
  • Reply by jerry_d
Thank you Herald. I appreciate you taking the time to share your experience and to offer your suggestions. Regards.
  • Posted 18 Nov 2009 03:51
  • Reply by jerry_d
Yes there is a problem with ring gears on the 39x range this has started to occur since the starter motor was moved to the other side of the bellhousing to allow for better access.
If you contact Linde the original part numbers should change to a tougher ring gear and a starter motor with a fitting kit that will modify the spacing between motor and bellhousing.
I have had a 391 ring gear last 2 months between changes,I fitted the kit and all seems well..
cheers
herald.
  • Posted 18 Nov 2009 02:30
  • Reply by Herald
Thank you for responding. We're very concerned. We've had to replace 1 ring gear but quite a few starters on vehicles that have less than 1500 hrs. Can't seem to see why the starters are failing and the Dealer hasn't offered much help. I would appreciate knowing as much as I can about similar problems others are having and what they've done to correct it. Thanks to anyone who can assist.
  • Posted 17 Nov 2009 06:18
  • Reply by jerry_d
