Skyjack SJ111-3219:
SJ3226 won't move backward
Hey guys,
I got an SJ3226 and the operator complained that the lift stop going backward all of a sudden.
Now it doesn't even respond to the command of the joystick when going back, but when going forward the equipement doesn't move, but you can hear the hydraulic unit going. The pins on the wheel doesn't go back in to allow it to move. Could it be a solenoid?
And if you have any ideas for the backward issue, would be greatly appreciated.
  • Posted 7 Sep 2018 03:56
  • Discussion started by michel_d
  • Quebec, Canada
Ty to take the joystick unit and plug it straight in the back of the skyjack where the ladder is. If it works fine you know your problem is in your harness between the base and the top cage.
  • Posted 23 Nov 2019 06:11
  • Reply by michel_d
  • Quebec, Canada
No the pump doesn't run. It will move a little then just stop
  • Posted 23 Nov 2019 06:06
  • Reply by ChiliMan
  • Wisconsin, United States
Ryan
Does the pump run when you activate the joystick?
  • Posted 23 Nov 2019 06:01
  • Reply by michel_d
  • Quebec, Canada
Do you remember hoe you fixed the reverse problem?
  • Posted 23 Nov 2019 05:44
  • Reply by ChiliMan
Ryan
Not that I remember. It sounds like the seal is bypassing in the cylinder.
  • Posted 17 Sep 2018 22:44
  • Reply by BREWSKI
Would there be any kind of safety valve or something that would prevent it from releasing the brakes?
  • Posted 17 Sep 2018 21:46
  • Reply by michel_d
  • Quebec, Canada
Just checked it and yes I do have oil going through the hose to the cylinder.
  • Posted 7 Sep 2018 23:03
  • Reply by michel_d
  • Quebec, Canada
Could be a stuck valve or a blown seal in the brake cylinder. Have you checked to see if there is oil delivery at the brake cylinder?
  • Posted 7 Sep 2018 22:22
  • Reply by BREWSKI
Solved the issue with the no backward problem, now it's just the brakes that won't let go.
Checked the relays they all seem fine, I've got power going in and out of the solenoids. Could it be the valve that isn't working properly?
  • Posted 7 Sep 2018 05:54
  • Reply by michel_d
  • Quebec, Canada
If this could give any hint, while playing with the control box, when I pressed the horn button the hydraulic unit started?
  • Posted 7 Sep 2018 04:49
  • Reply by michel_d
  • Quebec, Canada
Taylor T650L
UN Forklift FB25N1QZ1
Louisville, KY, United States
Dubuque, IA, United States
Linda Häkkilä Linda Häkkilä
