Hi all, I am chasing a fault code for a Shangli electric ride on fork... model CPDS18SA-E3
It has lost power steer, hydraulics(lift etc) and traction. it throws up fault code 06 and i was told a code 64 also came up.
Any help on this would be greatly appreciated.
Thanks in advance.
Hey everyone
I have shangli cb have faulted in code 2 evry one knows thats pls help me
sir i have one shangli forklift 80v , model CPD30 traction slow speed change also encoder , show error ,code , 63 and 64 and 91, have you manual or any help, thanks ,
[email address removed]
a
I think i found what i need, so for any one else that is interested...
Fault code 6:
A) The working voltage of the main contactor is lower than the rated voltage.
Check if the circuit is correct.
B) The main contactor is damaged. Replace the main contactor.
C) Control panel damaged, replace the control panel
