Secondary's hitting hard
Class 3 carriage, with a full free triple, secondary's hitting hard when they fully seat. Free lift cylinder of course is at the top of the stroke when secondary's start to raise, if I lift it 6 feet or 6 inches it slams when they come down, removed both secondary's for inspection, solid rod, no check valve inside either cylinder, looked good inside of barrel, re packed and reinstalled, replaced flow protection valve and lowering valve. Still slams, seems like return to tank is not restricting return flow. Checked for rails hitting something, not seeing any obstruction anywhere. Sounds like the cylinders are bottoming out. no cushion at all, just slamming, customer says it's been doing it for years. Any thoughts???
  • Posted 22 Aug 2015 20:51
  • By Burt
  • joined 22 Aug'15 - 3 messages
The model is a GC30S-3. Serial of 06-01660, I'm doing that from memory, as I'm not at the shop now. I did mention it was a full free triple mast, new carriage chains last month, upright chains done early this year, cam type adjustment on upright chains. All adjusted correctly, mast vertical, heels just off ground, removed carriage from mast and secondary's still slam. It's like the return flow is not slowing the secondary's.
  • Posted 23 Aug 2015 10:11
  • By Burt
chain adjustment?
really should give us a complete model and serial number, and in this case the mast number (and a good description (?full free triple? quad?) to get better opinions.
  • Posted 23 Aug 2015 00:39
  • Modified 23 Aug 2015 00:41 by poster
Maxlion FD50T
Kalmar DRF450-70C5XS
Maxlion FD50T
