I would think that would cause a continuous problem not a intermittent problem. But I'm glad it's working for you
turned out switch right below steer handle with 3-4 wires was wired improperly!!!
thank u ill give that a try.......be cheap fix !!!!
I always replace the main motor contactor in the Rss40 lifts. The contacts inside of them start to get dirty and you'll get the occasional welded contact error.
I get the White Rodgers 120-904 24 volt contactor off eBay for around $25
when u pull handle down and here a click u know its gonna go. when there is no click u know u are stuck for awhile
