Return grip to neutral message when turning left
Lift is giving a return grip (throttle) to neutral whenever you try and turn left going forward and reverse. No problems going straight or right, just left. Found two wires exposed in the X10 handle harness and taped them up. Also replaced the BRK2 since steering inputs go through it. Thoughts?
  • Posted 11 Jul 2024 07:08
  • By Michael_Webb
  • joined 24 Jun'20 - 24 messages
Thanks, replaced the harness after finding more problems with it. Lift is back to work as of an hour ago.
  • Posted 19 Jul 2024 08:17
  • By Michael_Webb
I really don't recommend just taping up the wires for the handle if some were exposed. Replacing that harness is your best bet otherwise in a few weeks you'll have the same issue again or one of the PCB board will short out if the wires make contact with the handle or tiller arm.
I recommend looking at the brake switches on the knuckle, the wires sometimes get pulled when turning in one direction or the other causing it to momentarily close the brake causing the return grip message. I would also check to make sure that the brake switch is closed for the full range of motion of the tiller arm as sometimes there can be a dead zone that momentarily opens one of the switches.
  • Posted 19 Jul 2024 06:38
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 226 messages
  • Wisconsin, United States
RAEDER-VOGEL
Enforcer FLBAXT25
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Enforcer FLBAXT25
USD1
RAEDER-VOGEL
