Report this forum post
One of my crown sp3020's has a hard plug in reverse. You'll be in forward travel above 2 MPH and try to plug in reverse and as soon as the reverse switch is engaged it will put the lift into a dead stop. Then reverse will not work. You have to key off and on in order to get reverse travel back.
I checked the POT and had a bad spot so I changed it out with a new one and adjusted it accordingly, but had no change in operation. Still plugging hard in reverse.
This all started happening after replacing the MOSFET. I swapped it out with a new GE IGBT Module.
Any Ideas?
  • Posted 12 Sep 2019 00:13
  • By Busch
  • joined 30 Jul'18 - 55 messages
  • United States
Never assume, assumptions are the mother of all ****ups. -Busch-
Indicates mandatory field
Combilift Ltd
Deborah Baker Deborah Baker
Muncie, IN, United States
