Linde (& Baker) H35D:
Replacing hoses - time?
How big a job to change out the two long paired hose assemblies (side-shift) running from the mast to the retractor reel? Working blind - not a brand I've seen before & no service manual for procedure. Any pointers much appreciated - thx
  • Posted 27 Apr 2019 22:38
  • Modified 29 Apr 2019 00:05 by poster
  • Discussion started by Nleonard
It's a bit of a sod of a job but shouldn't take much more than a 3 or 4 hours at the most the first time you do them. I normally do them in a couple of hours. You will,have to take the hose real out and before you do make sure you lock it in position so you don't loose spring tension
  • Posted 7 Jun 2019 02:58
  • Reply by lifter01
Johnston, IA, United States
St. Louis, MO, United States
Jefferson, WI, United States
edition #1234 - 12 June 2025
