Toyota 7FGU25:
Regulator question
Hi, model number is 7FGU25, serial number is 81130. Replacement regulator part number is 23530-U2201-71. I'm trying to find out if this is plug and play or if it needs adjusting after install. I have no experience with this, any help would be greatly appreciated. Some stores tell me that without a small tag on the existing regulator I risk buying the wrong part, but I cannot see a tag. The only number stamped on it are: Aison W.P.250P.S.1 (may be 8.I instead of S.1) and W.C.0311 L8S. The lift has been running rough since I bought it about 2 months ago, so Im not even sure this is the correct regulator. Thank you so much!!
  • Posted 19 Mar 2025 06:59
  • Discussion started by George_Palles
Am not sure of that part number but on the top of the assin converter if it has a screw that is an open loop converter you would have to adjust after you install if there is a hose about 3/8 going from the top of the assin converter to the side of the carberator there is a injector that converter is a closed loop and no adjustment can be made. if you have the one with the screw it should still start before you adjust. Most 7 series had the converter that is not adjustable.
  • Posted 23 Mar 2025 09:01
  • Reply by Scott_
Scott
Toyota 02-8FD25
Hangcha CPYD25XW71F-JC
Flesherton, Ontario, Canada
VETTER Industrie GmbH
In 1903, the first Tour de France was held in Paris. The cycling race had been postponed and prize money boosted after it failed to draw enough competitors. Invented to lift the circulation of newspaper L'Auto, it comprised of six long stages totalling 2,428 kilometres.
edition #1227 - 24 April 2025
It continues to be impossible to ignore the uncertainty surrounding the US administration’s tariffs with the last week's news around how the changing macroeconomic landscape will impact our sector... Continue reading
