Raymond Walkie Pallet Truck - Lift Pump/Motor Issue
Hi,
I had a Raymond Walkie 112 Series Walkie (aka 6000/8000) have its lift motor fail on me last week.
I sent the motor out for a rebuild, it came back and I put it back together everything the way it was.
Now when I try to lift the forks, the motor makes a loud whirring noise as if the motor is free-wheeling, but the forks will NOT raise. It sounds like the motor is just spinning completely freely inside but no hydraulic activity seems to be present, as if the hydraulic fluid reservoir was empty or something, but it's got the perfect fluid level!
Any advice?
Thanks in advance,
jake
  • Posted 3 Feb 2011 02:21
  • By GT42R
  • joined 28 Jan'11 - 36 messages
Hi guys, thanks for replys!
I was pretty sure that the rebuilder messed up and forgot a coupling inside that connects the motor to the pump...
I sent it back out today and it came back, so I think thats exactly what it was!
Thanks!
  • Posted 4 Feb 2011 08:20
  • By GT42R
Well, not really alot on these trucks. Check the lowering switches, if they are stuck closed, the truck is trying to lower the same time. The pump itself could be shot. Or like the guy said check your cables. I have had a lower switch on the grab rail fail, causing this problem before. Let us know.
  • Posted 4 Feb 2011 07:23
  • By tridski
  • joined 2 Feb'11 - 2 messages
  • Indiana, United States
Have the cables on the motor been reversed so now it is spinning backwards? Is the lowering valve solenoid somehow energized so it it trying to raise and lower at the same time?
  • Posted 3 Feb 2011 04:01
Terberg RT223
Taylor T520M
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
edition #1293 - 6 August 2026
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
Terberg RT223
Taylor T520M
