Raymond steering jamming
Raymond 31G DR-93-15925
Raymond steering jams only when the Hyd. oil gets hot.
remove steering link arms from drive and caster wheel -free !
swapped out steer orbital no different.
Only thing was changed was a caster wheel??
Any advise?
  • Posted 9 May 2014 16:49
  • By LOGIC
  • joined 6 Dec'08 - 70 messages
radial ring need help step by step raymond easi
  • Posted 3 Feb 2022 12:07
  • By Gusstone
  • joined 17 Apr'20 - 25 messages
easi your right disassemble the drive unit bull ring ,the band where damage.Had replace the drive unit.
Thanks for the heads up!
  • Posted 17 Sep 2020 04:23
  • By JKPAINTER
  • joined 26 Jul'17 - 73 messages
Check your bearing thrust on caster wheel assembly. I had the same issue and the bearing thrust was completely damaged.
  • Posted 17 Dec 2019 08:20
  • By Josue_Arana
  • joined 7 Nov'19 - 2 messages
Did this issue ever get resolved? I am having a very similar problem.
  • Posted 11 Dec 2019 09:15
  • By DTucker
  • joined 11 Jul'14 - 35 messages
D. Tucker
Jack up truck, install a dial guage on drive unit. 120 thou is real bad. there will be metal on metal contact once rings are shot. steering may seize
  • Posted 27 May 2014 13:07
  • By EasiTek
Not at all ! steering jamming when getting to the end of the steering in both directions
  • Posted 22 May 2014 02:26
  • By LOGIC
Having any other issues when the oil gets hot? Tilt , sideshift reach issues?
  • Posted 20 May 2014 09:17
  • Modified 20 May 2014 09:18 by poster
  • By ross_g
  • joined 12 Jul'05 - 18 messages
Caster Wheel brgings are O.K and i swapped out the Hydraulic steer motor out and same thing.The radial ring when braking the drive motor moves a lot.If the radial ring is the cause can u shot me a Re/Re repair steps and long does the re/re takes?
Tanks
  • Posted 20 May 2014 07:36
  • By LOGIC
You changed the Hydraulic steer motor? That usually goes. Are the radial rings worn? Drive unit could drag. Caster wheel pivot brg can seize too
  • Posted 14 May 2014 10:33
  • By EasiTek
Deborah Baker Deborah Baker
Muncie, IN, United States
