Raymond EASI S-EASI-950EA11384
Unit has Failure CODE 81- need HELP?????
Can't get any help from local dealer.
  • Posted 29 May 2009 05:03
  • Modified 8 Jun 2009 23:55 by poster
  • By ptusk
  • joined 29 May'09 - 8 messages
Try RAY 1 Or Ray 2 or Ray along with the last 5 digits of the serial number.
  • Posted 28 Jul 2009 12:25
  • By chublil
  • joined 28 Jul'09 - 187 messages
Fix it right!!!
Edward has said it all...
There is a faint chance that the truck is set at a default superword. If you check out the Raymond section in the mechanical troubleshooting section of the forumns you will see a number of discussions on what these are. It's a lengthy list.
  • Posted 29 May 2009 21:43
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
You are almost for sure going to have to "make nice" with the local Raymond dealer, and pay him to come out and run the "d-tech" software to reset the password, it requires a special cable and dongle to talk to the truck mangler, and even -if- you had the PN for the cable, dongle and software, the cost will most likely be more than the cost of the service call to get the Raymond dealer to come out and reset the "super-word" to what ever you want it to be.
  • Posted 29 May 2009 20:50
How do we get the Superword? We do not have any repair info on this unit. The local dealer will not help. Do you have any other info that would help?
  • Posted 29 May 2009 07:07
  • By ptusk
It means that your lift pot is out of range. You will need the superword to access the menu to see what the reading is in the system. The unit still should drive, but will not lift and lower.
There was an upgrade a few years ago on the Easi Trucks to a new optical switch vs a straight pot. If this was not done you'd be better off just replacing the handle with a new one with the upgraded guts. You will still need the superword to relearn the handle
  • Posted 29 May 2009 06:33
  • By JonG
  • United States
TCM FHD105Z
Crown CG33P5
TCM FHD105Z
Crown CG33P5
