Raymond Backwards
I have this problem? Raymond 112/ 2006
It has Rabbit speed in fork travel, not forward travel.
So it is opperating backwards from what it should.
Have sister truck sitting beside it,works correct.
Motor derection good, forward Reverse M/S good. Rabbit switches work.
RLY-1 works all wiring looks correct.But just backwards.
I have changed the controller with a know good one.
any ideas
  • Posted 18 Dec 2010 03:42
  • By pacfork
  • joined 2 Jun'07 - 55 messages
  • British Columbia, Canada
Showing items 1 - 19 of 19 results.
Thanks the hand set did read with the key on and handle up
We are shipping it back for now.
To much time spent on it so far.
and no answers yet
Thanks for you help.
May be from the factory it was wired this way?
Merry Christmas
Jeff
  • Posted 24 Dec 2010 06:43
  • By pacfork
Can you give me a call? I would like to talk it over.6305954450
  • Posted 24 Dec 2010 02:30
  • By mike_v
  • joined 1 Jul'10 - 190 messages
  • Illinois, United States
mike_retired
The brake sw must be on or off(don't remember if on or off )for the hand set to communicate with controller.
  • Posted 23 Dec 2010 13:22
  • Modified 23 Dec 2010 13:22 by poster
  • By mike_v
mike_retired
Can you explane some more?
The Brake switch is just a push button micro switch off/On?
  • Posted 23 Dec 2010 10:39
  • By pacfork
Its related to the state of brake sw.
  • Posted 23 Dec 2010 07:06
  • By mike_v
mike_retired
I have changed out the horn doide block with know good one still does not work.
I tested motor to frame short Nope.
Have you guys had any problems with the hand set not reading the controller at times.
It now says connection error, But yesterday no problems.
  • Posted 23 Dec 2010 06:05
  • By pacfork
I will check in the morning.
Do you know if the diode block near the horn would have any effect on the rabbit speed?
Pt #154-010-796
it does not inter change with the hour meter diode
the truck next to it being a 02 does not have this.
The only Doide from SMH is in Kansas
$30.00
Will advise
  • Posted 22 Dec 2010 10:19
  • By pacfork
Check motor(field leaking to truck body)
  • Posted 22 Dec 2010 06:37
  • By mike_v
Mike I have switched the DA-3 with the good truck,Nope
I will look at the Belly button circuit. But it work in reverse.
So should work in forward
But will check circuit.
Jeff
  • Posted 22 Dec 2010 06:10
  • By pacfork
Check the diode block(connector DA3)
  • Posted 22 Dec 2010 03:13
  • By mike_v
mike_retired
First, for those that stated that rabbit speed should not work in forks first travel, the latter 112s and the newer 8400s have rabbit speed in both directions.
Pacfork, check the horn switch cut out circuit for the emergency reverse switch.
  • Posted 22 Dec 2010 02:55
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
Sorry I guessed wrong at the year.
S#112-00-30709
My question is the controller is seeing the signal from the rabbit speed switch in reverse what changes in forward.
They would not run the signal through a N/C Forward switch?
Jeff
  • Posted 22 Dec 2010 02:47
  • By pacfork
I will be glad to help you, however please supply the truck serial number eg 112-05-xxxxx or 840-06-xxxxx. The reason is that in 2006 the trucks manufactured were 8000 series models, ie 8300, 8400 etc.
Rabbit only works in tractor first direction.
  • Posted 21 Dec 2010 09:49
  • By MountainMan
  • joined 9 Aug'08 - 2 messages
I think these is a pallet jack in question and for this kind of machine rabbit speed should be enable in forks direction only, unless the handle its in riding position.
  • Posted 21 Dec 2010 00:57
  • Modified 21 Dec 2010 01:24 by poster
  • By mike_v
mike_retired
Mike, your suggestion is that for an Orderpicker, man up truck, (or pallet jack), the full speed be set to happen when fully lowered, while the operator is turned away from the steering hand crank and speed control, and will have the steering and drive unit in the trailing. is that correct? most operations I have seen have full speed enabled when the steering and power side of the truck is in the leading position
  • Posted 20 Dec 2010 21:28
  • Modified 20 Dec 2010 21:31 by poster
Yes I'm wright, think about it.
  • Posted 20 Dec 2010 10:21
  • Modified 21 Dec 2010 00:46 by poster
  • By mike_v
mike_retired
not correct, for safety reasons - rabbit should NOT work in forks direction. Just think about it.
  • Posted 20 Dec 2010 05:43
  • By just_m
  • joined 13 Jan'10 - 9 messages
For safety reasons rabbit speed should work in forks direction only.
  • Posted 20 Dec 2010 01:48
  • By mike_v
mike_retired
did you plug in the diagnostic tool? If i remember correctly rabbit can be turned on/off for a particular direction of travel
  • Posted 18 Dec 2010 09:24
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
