Raymond 8210 can't enter into Key pad
Hey guys, great site and a lot of help. Got this unit that "boots", then ODI just displays 4 dashes, can't enter anything on keypad. Installed new key pad and same problem. Two questions, can I use the interface to disable pad, and what would cause this issue. Have a green led heartbeat on ETAC. HELP!
  • Posted 20 Jul 2017 11:28
  • Discussion started by 1sharpdog
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
I'm having the same issue, did you resolve your problem.
  • Posted 10 Mar 2022 06:49
  • Reply by Mike_McDonald
Mike McDonald
I was replaying to original post. You start your own thread.
  • Posted 14 Jun 2019 10:00
  • Reply by ivan_j
Really?
I ask about accessing programing and you come back with that!
  • Posted 6 Jun 2019 04:57
  • Reply by pacfork
  • British Columbia, Canada
Take controller out. Open it. Probably burnt inside.
Also check for welded line contactor and welded lift solenoid.
  • Posted 5 Jun 2019 07:50
  • Reply by ivan_j
Hi Guys
I have similar problem BDI will not reset battery volts 25.2
have service key trying to read VM battery volts.
After d is selected segments only flash 8 scolls each segment.
Trying to read battery volts at VMC which should be ! then battery symbol but can not get there any help. tried everything
  • Posted 5 Jun 2019 07:39
  • Reply by pacfork
WE CHANGED THE CONTROLLER, THE HARNESS, THE HANDLEBAR, THE HANDLEBAR CARDS. BUT IT DOESN'T GIVE TRACTION.
  • Posted 1 Jun 2019 07:46
  • Reply by alonso_reyes
  • kyku, France
Probably ETAC in tiller handle, had same problem today, or etac isnt fully seated on display.
  • Posted 31 May 2019 12:09
  • Reply by 1sharpdog
I have the same problem and do not know what to do! As I solve the problem, I don't have the programming key i dont Have a computer
  • Posted 31 May 2019 02:47
  • kyku, France
What adapter you need for flashware for 8400?
  • Posted 8 Aug 2017 10:08
  • Reply by ivan_j
I have the programming key, won't boot. Have a computer, no flash ware!
  • Posted 8 Aug 2017 02:49
David Sharp
Do you have flashware on a laptop ?
  • Posted 28 Jul 2017 23:35
  • Reply by DanMc
Hangcha FLDCXT160
TCM FD115-3
edition #1235 - 19 June 2025
Combilift Ltd
Hangcha FLDCXT160
Tusk 500PGH16
Wentzville, MO, United States
Ottumwa, IA, United States
Harrisburg, SD, United States
