Unicarriers (& Nissan) CHP02L25E:
PS Problem Error code
Hey we've getting a error code on our forklift and i cant seem to be able to look up anything about it how to fix it so wanted to ask you guys here. So on our forklift we've been getting a error code reading PS Problem 530, 514 013
I looked up the codes and that came up was something was wrong with the transistors and related parts. Im wondering how I would be able to check the parts on the forklift myself or figure out what parts to buy as other forklift repair places charge labour for inspection alone which takes 3 days to do. Which is absurd so if anyone can help me out with this much appreciated!
Edit: I did the self diagnostic check on the machine and I got
- PS-TR *514
- PS- C sensor *526
- Short /V.OVER *530
  • Posted 28 Feb 2015 07:59
  • Modified 28 Feb 2015 08:41 by poster
  • Discussion started by Mike_TD
  • Alberta, Canada
Showing items 1 - 15 of 18 results.
Hi we have encountered same error code 514.530
Upon checking we notice ps.c not activate.
We have change out the 2 igbt still the same problem.
Does ps.c need to be energized first or isit because of the fault that cause it not to activate.
  • Posted 4 Jul 2022 18:04
  • Reply by Darren
  • Singapore
For the benefit of others- Nissan P02 had power steering fault-codes 514 and 526. Tested IGBTs -one bad, replaced both upgrading from75A to 100A. Also changed current sensor because it showed.2 ohms instead of the.01 ohms stamped on it. New one had same resistance of.2- opened old and it is simply a corrugated resistance strip encased in cement- very simple- if continuity then probably good. New IGBTs didn't remedy. Sent board to uniparts, they found issues and warned to check IGBTs before install, as bad transistors will again blow the repaired board (the former go first then the board). Now functioning. Fault was probably caused by an obstructed steering wheel. Keep battery volts up (thus current normal)and set steering assist current level to 85% instead of 110% (press FN! and 3 at key-on, scroll down to PS). Uniparts said they do these repairs continuously.
  • Posted 10 May 2022 04:12
  • Reply by tjon
Has same issue with the steering. replaced motor first then four sets of ibgs in till it worked. Ran good for a week. then burnt out motor. replaced motor and now have very little steering assist. removed tested and regreased motor drive unit. checked steering box and tried spare card. ran new wires to motor and even another set of igbs from dealer and changed current sensor. I seem to be only getting 8vdc to motor. an amp probe on lock shows 24 amps. unlocked i see 1 amp.I just got in a 3000 with similer steering and so far i know the card is good. will be testing the rest later next week.
  • Posted 14 Apr 2018 08:52
  • Reply by ifsmike
when all else fails ,stand back and observe
Thanks for sharing this information.
  • Posted 4 Apr 2017 23:45
  • Reply by elaine_d
  • Louisiana, United States
I got my card back today from Nissan,they said it did have a issue and they fixed it, how ever ,,,,,, I'm having the exact same issues ,it is steering only one direction and it is still not accelerating properly,u had mentioned a steering sensor on the colum and also checking the foot switch pot,could u go into more depth, Im just about at the end of rope lol,any advise or thoughts would be great
  • Posted 30 Mar 2016 10:04
  • Reply by tony_a
  • West Virginia, United States
If you know how to check sensors and such through the meter panel, i would start. Verifying proper accelerator pot voltages and smoothness of the voltage ramp while slowly operating accelerator will sure shorten the diagnostic time on this. Then again it could have been a card issue all alone.
  • Posted 8 Mar 2016 23:44
  • Reply by RCAV8TOR
  • Alabama, United States
thanks for the reply and info, i can reverse the steering wires on the motor and get it 2 steer the other way,i dont know what that means,also i sent my card and transistors off to nissan to be checked,let me rephrase the acceleration issue,its not really jumping its like its going into the higher tram u have to push the accelorator almost all the way down to get it 2 move, does that tell u anything
thanks tony
  • Posted 1 Mar 2016 02:26
  • Reply by tony_a
If you now have steering to one side and not the other then it is possible you have a mechanical binding in linkages or bent power steer cylinder screw. Also the steer sensor that is mounted to the steer sector could be flaking out and or damaged card.
As far as the jumping on acceleration could be due to setting of acceleration rate, drive motor brushes, accelerator pot and or damaged card.
  • Posted 1 Mar 2016 00:35
  • Reply by RCAV8TOR
We just installed new igbts set, we didn't have any ps now we have it steering to left only, also the machine isn't running smoothly it started jumping when u accelerate any advice would be appreciated
  • Posted 27 Feb 2016 13:22
  • Reply by tony_a
Hello, I came across this discussion,I have a Nissan electric lift that is giving me ps problems it will steer one way but not the other,has anyone ever came across this problem any input greatly appreciated
  • Posted 26 Feb 2016 12:18
  • Reply by tony_a
Also, remember to run a complete diagnostic check after installing new idgets,and replacing or unplugging panel, prior to attempt steering of unit, learned this the hard way, above advice is very good, also has been awhile since I worked on one, but them little wires were famous for coming unplugged.
  • Posted 22 Aug 2015 21:10
  • Reply by Burt
As RCAV8TOR suggested I would start with verifying the correct operation and calibration of the steering sensor and the mechanical parts that operate it (located in bottom of column below floorboards).
  • Posted 26 Apr 2015 01:19
  • Reply by Forkinglift
  • Wisconsin, United States
Mike this is where i am thinking the problem originally started with steering. Verify that you have the igbt's properly wired. If you know how to get into diagnostics screen then go to steering sensor. What you want to look for is neutral, left and right parameters. See if the sensor is with in these parameters. If not then ahjust the sensor or you have a bad sensor or lever in the steer sector. Next inspect the linear actuator/ power steer cylinder to see if it is bent. You will need to remove the clamp from the rubber boot at the tail shaft and slideback toward the front of unit. With unit jacked and blocked up. turn the steering until the rod is fully extended. It will be a screw drive. if it is bent, it will bind. While up in the air also check the king pin thrust bearings as well. Check back with what you find.
  • Posted 25 Apr 2015 03:46
  • Reply by RCAV8TOR
Ok steering has been restored however a new problem has come up. there isnt any electrical problems according to the self checking but steering is very hard in only one direction. The forklift can turn left very easily but turning right the wheel becomes very stiff and hard to turn.
Also this is after we changed out the IGBT transistors and repaired the board. the wires have all been plugged in the right order now and all electrical problems seem to be out of the way.
  • Posted 25 Apr 2015 00:33
  • Modified 25 Apr 2015 00:38 by poster
  • Reply by Mike_TD
  • Alberta, Canada
Small control wires on igbt's should be installed as follows:
(green&yellow) (blue&red) (pink&white) (black&orange)
  • Posted 17 Apr 2015 08:40
Have a nice forking day.
SMV (Konecranes) 32-1200C
Hoist Liftruck F180-36BOX-CAR
Your Focus
St. Louis, MO, United States
Jefferson, WI, United States
Johnston, IA, United States
GemOne
UN Forklift FD25T-C2JM1
TCM FD115-3
