Problem with Linde H45D-03-600
My Linde has a problem with going forward and backward. When I press the pedal for going forward or backward at beginning he do nothing and suddenly he make lunge. I can't see a plate on hydraulic pump or plate on valve where the pedal goes. It would be great if someone could tell me type of the pump or valve. I would be very happy with information about inlet pressure of that valve.
Thank You in advance
  • Posted 6 Nov 2012 20:37
  • By phy_p
  • joined 6 Nov'12 - 1 message
  • Croatia, Croatia
Adelle. check seat switch. Their is also a brake switch under floor board by the brake valve. Check also wires at potentiometer under floor board
  • Posted 9 Oct 2016 13:00
  • By edward_m
  • joined 11 May'15 - 111 messages
Just started getting back on. Not sure where your at with your unit.Let me know
  • Posted 23 Jan 2016 14:01
  • By edward_m
Hi Edward m,
Hope this email finds you well. It seems like you are clued up with forklifts. We have problem with our Linde H40D, with no manual and indication of where to start looking. The forks works well but no forward and reverse. Can we please get assistance or any indication please.
  • Posted 19 Aug 2015 17:27
  • By adelle
  • joined 19 Aug'15 - 1 message
  • Gauteng, South Africa
Might check under floor board and remove cover to pedal linkage. Rod that goes through pedals will shift. If you can get it hooked up to a laptop you can go to imput /outputs and jack up one side of drive wheel and when pressing pedal forward or backward, wheel should start turning when voltage gets to 460 milliamp. its a start
  • Posted 24 May 2015 04:23
  • By edward_m
Autolift E180AT36B-D5-180
Toyota 4FD240
Noblelift
