hi i have problem with DAEWOOD serial #G30S-2 MODEL #12-04044
unit drive forward and reverse with no problem but soon start to steer the unit lock up seems like drive axles are sleepily seems like the differential has something in side and don't let gears turn smooth, i had replace the shaff- assenbly because it worn little and and maybe fix the problem it didn't work one more thing i did was remove both sides drive axles to see if one was worn or broken thy look ok
any ideas i appreciated thank you much,
