Problem I can't identify
We're having problems with out Toyota 8FDU25 shutting down. The engine will still idle but the machine loses power and can't move. We have tried replacing the accelerator and the ignition so far without success. Problem seems to occur randomly. Thanks in advance for any help you guys can provide.
  • Posted 13 Dec 2016 01:13
  • By logan_r
  • joined 13 Dec'16 - 1 message
On a diesel, if it won't accelerate it has to be a fuel problem as there is no ignition system. Check the fuel filter. If it's OK it's best to call the dealer. They have a plug-in analyzer that can check the injectors as well as the common rail pressure. Much cheaper than throwing parts at it.
  • Posted 22 Dec 2016 06:12
  • By ramon_m
  • joined 30 May'14 - 42 messages
