Press on tire disposal
Any one out there that has found away to get the rubber off of a solid cushion old tire so the metal can be scraped and the rubber sent to a recycle r , is there such a machine out there?
  • Posted 15 Feb 2019 02:28
  • By stillworkin
  • joined 2 Nov'18 - 96 messages
They only do load wheels.
  • Posted 25 Feb 2020 00:32
  • By Robert_Hertig
  • joined 25 Feb'20 - 1 message
Hi Royaltyres. Your email address got deleted. Please email me. You can find my email address in my profile.
  • Posted 7 Aug 2019 10:45
  • By Yidneck
  • joined 20 Jan'17 - 110 messages
Dreamt I was fixing a machine, then came the paperwork and it turned into a nightmare.
I had a customer that collected and shipped old auto and truck tires to china. They would freeze them with liquid nitrogen (or something to that effect) and then pulverize the rubber to little pieces. They told me the steel inside the tire would come out looking brand new and be recycled while the rubber was used in power generation facilities since it contained more BTU's per lb than coal.
I don't know if that would work with press on tires with the steel band being so thick but it is an avenue not discussed above.
  • Posted 1 Aug 2019 22:50
  • By SansPeur
  • joined 9 Dec'11 - 3 messages
  • United States
Hello friends, Whilst we work over-time to ensure that there is no bonding failures on Press-on Tires, you folks are bent on breaking it.. really hilarious. No one takes it that press-on tire fitted Forklifts are to be used purely on indoor applications.. they use it everywhere including on litter, grease, oil, etc. so we need to ensure that bonding is virtually un-poachable.. but there is a safe way out without costly machines.. but you'll need couple of unskilled hands. Just email us at [email address removed] for that free tip..
  • Posted 20 Jul 2019 14:38
  • By Royaltyres
  • joined 20 Dec'09 - 10 messages
  • Tamil Nadu, India
Sendil, Royal Tyres, India.
  • By Royaltyres
  • Tamil Nadu, India
thank you for that info i will check with them
  • Posted 13 Jun 2019 23:17
  • By stillworkin
I believe it's too much hassle to deal with trying to recycle them yourself. You can likely find an auto recycler in your area that will take them off your hands. They can put them in junk cars to be crushed and then shredded.
The shredder can handle them very easily and everyone wins.
  • Posted 13 Jun 2019 21:41
  • By tom_w
  • joined 29 Jul'04 - 24 messages
  • Virginia, United States
I agree there is a great need for this ,I tried a hot wire to cut the rubber with bad results. dose not work thanks for the reply
  • Posted 5 Jun 2019 22:28
  • By stillworkin
there hasn't been an easy way invented yet to do what you are inquiring about.
like Darren said, there have been some tire companies or independents that have engineered some sort of way to do this but as of yet nobody has invented a machine to remove the rubber off the press rings easily and safely.
So its either cutting, heating the bond and brute forcing by press, or burning the rubber off.
This is an open concept begging for someone to invent a machine to do this task. ;o)
  • Posted 5 Jun 2019 21:58
That is what I am interested in , something that can tear the rubber off the rings , The other method is pricey and time consuming, I have found some that will burn it off and leave dust. again to expensive and slow.Thanks for getting back to me.
  • Posted 5 Jun 2019 01:54
  • By stillworkin
I've seen a couple of home grown solutions.
One involved a vertical lathe type of contraption, that pushed a large blade into the rubber and peeled it. Bent steel bands broke tooling often.
The most effective was using an induction heater on the steel band to break the bond. You need a good extraction system system though as the gases aren't good.
  • Posted 5 Jun 2019 01:21
  • By Darren_MH_Tires
  • joined 5 Jun'19 - 3 messages
maybe you'll need a tire press machine.
  • Posted 23 Feb 2019 20:07
  • By kecy_w
  • joined 26 Nov'11 - 13 messages
  • Guangdong, China
Thank you,, however looking for machine to use so we may provide this service locally
  • Posted 15 Feb 2019 06:11
  • By stillworkin
Millennium Tire has a green wheel program where they will recycle your used wheels.
  • Posted 15 Feb 2019 05:12
  • By Partsguy5
SMV (Konecranes) 4545CCX5
Mitsubishi FGE35AT
