Ingersoll Rand VR-90C:
perkins engine quits running
Ing.Rand vr-90c zoom boom with I believe is a perkins 1004-4t diesel.For the past while the engine has always had white smoke at long idle periods.Now the engine will run at high RPM for about 3-5 minutes,then just die.It is hard starting after that.Sometimes the fuel filter is half empty.Sometimes will start after playing with the fuel system,or by cranking and putting the throttle wide open...any suggestions?
  • Posted 3 Sep 2009 03:45
  • Discussion started by djam
  • Alberta, Canada
did filters,etc,etc,even ran it with out fuel cap to see if it is creating a vacuum.when it dies there is nothing coming out of the injection pump
  • Posted 4 Sep 2009 02:13
  • Reply by djam
  • Alberta, Canada
Hello, Check the simple things first. Diesels hate fuel contamination. Change fuel filter - bleed system properly - check to see there is no water - dirt - garbage floating in the fuel tank. Start there hope it helps
  • Posted 3 Sep 2009 23:39
  • Reply by Prentice
Toyota 8FD35U
Flesherton, Ontario, Canada
Enforcer FLBAXT25
Your Focus
Johnston, IA, United States
St. Louis, MO, United States
Jefferson, WI, United States
UN Forklift FD35T
JCB 533-105
edition #1234 - 12 June 2025
