oil light
Presently working on a Hyster 90 forklift, Model#H90XMS; Serial#K005V3382Z and the oil light flashes on and off continuosly. There is plenty of oil in the motor and the motor runs fine. Any suggestions on where to look first?
  • Posted 4 Nov 2009 04:12
  • By ray_s
  • joined 2 Oct'09 - 58 messages
  • Alberta, Canada
I know it seems like a waste but check the oil pressure itself first, often you can find the O/P sensor and hook a gauge up quicker and easier then cleaning all of the grounds and if there is a legitimate O/P issue it shortens troubleshooting time and keeps you from running a motor with low oil pressure any longer then you have to; for me it is 5-10 minutes well spent.
  • Posted 5 Nov 2009 01:44
  • By notoriousDUG
  • joined 5 Nov'09 - 6 messages
  • Illinois, United States
If after all grounds are cleaned and reinstalled, where is the pressure switch located? Keep in mind this machine has a cab installed on it and makes it difficult to see inside the engine campartment.
  • Posted 4 Nov 2009 21:48
  • By ray_s
  • Alberta, Canada
Remove all of the grounds form the engine, trans, and chassis, clean and reinstall them. This has always resolved 90% of my flickering dash light issues and it doesnt cost any money in parts. If that doesnt work change the pressure switch.
  • Posted 4 Nov 2009 06:36
  • By bigGlittlestar
  • joined 12 Aug'08 - 139 messages
  • United States
Hyster
