ODS steering
This machine is an A/C unit with on demand steering. Most of the time it works great but some times the power assist is reduced by about 50% ( including motor speed ) but still responsive to steer wheel movement. When steer assist is reduced and I unplug the three wire plug at the motor, it goes in to high and I have full assist but goes back to reduced steering when plugged back in.
I replaced the steer sensor on the column and the trigger wheel on the column shaft is ok.
Is it the master or traction controller operate voltage for this function and how to check.
Thx
  • Posted 12 Oct 2015 00:30
  • By BrewCrew
We`re here for a good time
We had the laptop plugged in but would not register voltages for steering or any codes. Your saying there is a controller in the steer motor? I thought maybe a decoder on the end housing bearing.
Would you have a parts break down of the steer motor ?
thx for the reply BREWSKI
  • Posted 17 Oct 2015 07:54
  • By BrewCrew
Sounds like the controller on top of the motor is failing.
  • Posted 17 Oct 2015 05:55
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
edition #1301 - 1 October 2026
Forkliftaction News is excited to launch our Big Picture Interviews. In this thought-provoking series, we ask industry leaders for their insights on current market dynamics. In this week’s interview , Ralph Cox, Toyota Material Handling Europe’s SVP market operations, talks about why lean manufacturing and automation go hand-in-hand. Keep an eye out for the fortnightly interviews... Continue reading
The largest butterfly in the world is the Queen Alexandra's Birdwing (ornithoptera alexandrae), with a wingspan of up to 31cm (just over 12 inches). It is an endangered species only found in Papua New Guinea.
