not starting
Hi, I have a hyster S60XM serial number is D187V17353X. Has a 2002 mazda 2.2l engine in it. Im getting fire to my coil and plugs. Lift will crank over and start hitting as long as key is turned soon as I let off of the key it dies out. Almost like a fuel issue, I have cleaned the carburetor it still does it. Is there anything these lifts are notorious for that could be causing this or is it going to take getting a service tech out to hook it up.
  • Posted 5 Mar 2015 01:37
  • By cgarner1979
  • joined 13 Dec'13 - 24 messages
  • Alabama, United States
or a faulty keyswitch
  • Posted 5 Mar 2015 13:42
you may also have something as simple as a wire off on the key switch.
  • Posted 5 Mar 2015 10:55
  • Modified 5 Mar 2015 12:06 by poster
Electronic or point ignition , if points then check the ballast resistor on + side of coil(. 12 volt when cranking and approx 7 volts when running)
Timing belt could have jumped a tooth/. Food for thought
  • Posted 5 Mar 2015 07:14
  • By BrewCrew
We`re here for a good time
This unit is a gas engine.
  • Posted 5 Mar 2015 01:44
  • By cgarner1979
Philadephia, PA, United States
Chandler, United States
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
