Yale GLC050VXNVSE085:
No start
This unit will not start..I have fuel to injector at bottom of housing but no power to injector...
Cannot access diag mode in dash to check for codes...
HELP
  • Posted 25 Sep 2014 06:53
  • Discussion started by racinjunkii
usually the last active code shows up on the display.
the only reason to look in the service menu is to pull a history out of the error log.
a serial number from the truck will go a long way in helping diagnose this problem.
But first thing i would check are the fuses and wiring associated with the injector.
  • Posted 25 Sep 2014 20:30
  • Reply by swoop223
Dubuque, IA, United States
Louisville, KY, United States
