No start, fuel blowing through the injector?
I recently rebuilt the vaporizer and checked the fuel pressure at the big plug on top, pressure holds a steady 4.5 psi but I can hear whooshing thru the hose going to the injector holder. This is the first time attempting to rebuild the regulator and don't know if it's a straight parts swap or is there an adjustment on the lever or diaphragm.
Could the fuel be passing through the injector?
After rebuilding the regulator, the truck started and ran and fuel pressure was a steady 4.5 while running. Next day no start. I don't want to just throw parts at this truck.
Someone have this happen to them?
  • Posted 24 Aug 2021 13:17
  • By raymond_j
  • joined 28 Feb'17 - 17 messages
I can't fix stupid, but I can fix what stupid does.
Sounds like the injector on the throttlebody is bypassing. Easiest way to check is to pull off the intake horn on the top of the throttle body and turn the key on.
When you turn the truck key on with the engine off there should be no noise or propane smell.
If there is I would remove and inspect the large fuel injector. There is an oring to seal the injector end to the throttle body that always breaks causing propane to flow into the throttle body at all times when the key is on.
If the oring is good I have also seen the assistant injector (looks like a large six sided nut with two black wire coming out the back) get stuck open causing the same problem. Unplug and unscrew injector from the throttle body and check the pintle, sealing surface and return spring.
Both of these issues will cause a no start as the engine is flooded with to much fuel to start.
Hope this helps
  • Posted 26 Aug 2021 09:26
  • By BLey
  • joined 31 Jul'20 - 60 messages
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
Still GX10
Still GX10 2000
Poland
EUR950
UN Forklift FD30T-NJM1
Still GX10
Still GX10 2000
Poland
EUR950
