Help toyota worked fine yesterday now following morning nothing no start it will crank for ever no start. Checked for fuel no fuel coming to throttle body, no power going to both solenoid and lock off valves on fuel regulator. Checked for spark at plugs and no spark checked for power going to distributor and no power. Checked fuses all checked out good. Checked relays on lh side step checked connectios. Took harness apart and looked for broken wires found nothing. Only way I got it to turn on is if I supply power to the wire going from relay to distributor and supply power to wire going to solenoid and lock off valve on regulator it will start right up but the foot pedal for the throttle does nothing what iam I missing problaly something simple please help anyone
