No Hydraulic lift or tilt But steering works
Unit was worling and the hydraulic functions just stopped no warning , truck starts and drives fine.
  • Posted 14 Sep 2023 00:21
  • Modified 14 Sep 2023 00:21 by poster
  • By Barracudabear
  • joined 4 Feb'16 - 12 messages
Inspect the LLS solenoid on the right of the valve body if you havent already. There should be BV to it and also 10 ohms on coil. When started and seat switch on. If not remove and clean. Make sure good ground and it pulls in while in your hand with key on and off. Just had the same exact experience. That was the repair for this p6000
  • Posted 11 Oct 2024 02:15
  • By ron_k
  • joined 2 Apr'15 - 128 messages
  • North Dakota, United States
4kliftman
Hey i see this post got no replies, but i have a E10000 that is experiencing the same issues did you ever find out what was causing your issue
Thanks
  • Posted 1 Aug 2024 02:05
  • By ABKnucklebuster
  • joined 1 Aug'24 - 1 message
  • Alberta, Canada
ROYPOW
