I have a linde H35D, I have no forward or reverse, but I can use the lift and then I can get forward and reverse, will drive all the time until shut if off, then no travel until use the lift. I have changed the seat switch.
hello , problem can also the accelerator, be sure they are correct. Need software for calibrate.
Also check rpm sensor on starter ring flywheel, input need for drive.
H2X393B00339, it only had one seat switch
I did change seat, didn't take care of problem.
wich serial? Newest version have 2 switching points in seat , but if problem give always error so give serial.
