Mitsubishi FD -25:
No drive
F85 showing on dash
All icons flashing no drive fwd or reverse
Seat sw ok
Belt sw ok
Have all HYD functions
Any help would be great
Thanks Keith
  • Posted 6 Jun 2023 13:38
  • Discussion started by keith_roberts
  • New South Wales, Australia
Not sure if this will help or not
F-85 - T/M forward solenoid - Current above 180mA or more continued for 600ms when solenoid is off. OR current value of 3.8A or more continued for 200ms
Check Forward solenoid wiring and connector for issues. Make sure connector pins are seated correctly free of corrosion, make sure battery negative wire is in good condition. Check VCM and connectors for broken wires and corrosion.
Pneumatic truck transmission solenoid resistance check should be 4-7ohms
Cushion truck transmission solenoid resistance check should be 5.4ohms @ 20C degrees
VCM monitors amperage to the transmission solenoids not voltage. Check with low amp clamp.
  • Posted 6 Jun 2023 20:55
  • Modified 7 Jun 2023 07:48 by poster
  • Reply by BLey
KION reports dip in Q1 revenue Frankfurt am Main, Germany
edition #1229 - 8 May 2025
Taylor T650L
Terberg YT220
