Nissan Throttle position sensor
Working on a MCPL02A25LV. Wondering if there is a way to adjust/set the throttle position sensor without hooking up to the computer?
Thanks.
  • Posted 9 Aug 2012 02:19
  • By ATK1
  • joined 27 Jan'12 - 74 messages
  • South Dakota, United States
allenk@ntlifts.com
The throttle position sensor on the throttle body and yes the learn procedures.
Thanks.
  • Posted 10 Aug 2012 10:09
  • By ATK1
allenk@ntlifts.com
I kind of wonder if we might be using differing terms.
are you wanting to set up a new throttle position sensor (on the throttle body), and want to run the learn procedures?
or are you looking to set the accelerator pedal position sensor (which can be done with a volt meter)
  • Posted 10 Aug 2012 09:35
electronic throttle control?
no not generally
you might get lucky and hit the correct voltage range the ecm is looking for but usually you have to set those in a pre-determined voltage range before the ecm will allow the truck to run correctly after its pre-start check.
  • Posted 10 Aug 2012 07:46
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
UN Forklift FD35T
UN Forklift FD15-18T
Hyster
Muncie, IN, United States
Hyster
Hyster
