Nissan Platinum-Lo2- overheating
Has anyone had overheating with the Nissan Lo2.Have replaced quite a few headgaskets/thermostats but after about 100 hours it happens again.Machine shops have found nothing at either times??(no help from Nissan also)
  • Posted 1 Dec 2006 08:04
  • Discussion started by jerry_o
Platinum has the same radiator as the old cpjo2?The only one i have worked on has the plastic tanks on the side like our cats.How many diffrent radiator configuations are they?
  • Posted 3 Dec 2006 23:58
  • Reply by proshadetree
  • Tennessee, United States
Thought when they said the same rad is being used sounded like a bad idea,never had a rad out yet.
  • Posted 3 Dec 2006 12:29
  • Reply by jerry_o
Got quite a few cpjo2 lifts running and they are water pump eaters. Radiators seem to bust at seams.Correct me if I am wrong but the platinum uses the same set up as the new cats.I have sevral of these running also,But no head gasket problems.Might want to take a cold lift and let it run till theromostat opens then rev engine to see if coolant if flowing.Im going to assume you have had a least 1 radiator flow checked.
  • Posted 3 Dec 2006 11:59
Seems that these machines run full tilt at 16klms/hr 15hrs a day.We have 35 on our floor all around 4000-9000 hrs 85% have had a headgasket.I have tried an infra-red gun that seemed to show only a slight indication of a possible thermostat failure.We just had a machinist come in do various head/block checks he took a headbolt with him saying that our multilayer steel gaskets might need a different torque and maybe different bolts??
  • Posted 3 Dec 2006 11:48
  • Reply by jerry_o
I hate to sound stupid but have you verified the overheat with a external sorce?Have you spot checked to find out if your flowing?An inferfred thermometer might help if you have access to it.Will show temp diffrence to help locate where flow stops.
  • Posted 3 Dec 2006 10:56
edition #1234 - 12 June 2025
Your Focus
