Model: CWP02L25S. SN: CWP02-9C2823
Turn Key switch on and Contactor pulls in but dash dosent light up and has no FWD/REV or Hydraulics.....lights and horn work and if shift lever is put in Reverse the back up alarm comes on....operator just took it off the charger and plugged it in but it won't do anything other than I just stated....Main power fuses all good...battery voltage is good @ 38.2 Volts(36 volt battery).
Fuse box in the controller are with the ATF style fuses...all them check good...have battery voltage on both sides of the main ( 275 amp) fuses and the power steering fuse(50 Amp).....any touts or ideas where to go from here???? I DO have the schematic and the CS and EL sections of the manual....
The unit should run without the meter panels or meter panel printboard installed as this is not a CAN BUS set up.
As MR stated, check seat switch. Possibly unplugged short harness on seat or possibly unplugged from seat switch. If all good then check the cabin relay ( located beside horn relay underneath floor pan on left side). I am on the same page as MR since dashlight do not light up. Be sure to double check the 20 amp atc fuse in the f box if truck is equipped with a brake booster set up also.
will check those this AM when I get back to the truck......first time working on this control system so.......
Kevin t;
Do you have a seat switch issue? Do you have battery voltage at the orange and yellow wires of the meter print board?
ALSO the fusible links at the negative termination look good and not burnt or anything...or will the break internally and only way to check is ohming them???
