Nissan K1B1L15 (Japan) Error code 558.
Hi.
Problem with Nissan K1B1L15 (Japan).
The fault code that appear in the screen are 558.
Can anyone help me with that?
My E-mail: info@pogruzchik dot net dot ua
Thank you!
  • Posted 17 Nov 2011 18:15
  • Modified 17 Nov 2011 18:16 by poster
  • By Igor
  • joined 17 Nov'11 - 1 message
  • Kyiv, Ukraine
I got the same problem with my Nissan p1b2l25u it also showing 558 communication problem. there anyone that can help.
  • Posted 20 Jun 2025 12:17
  • By songyot_v
  • joined 8 Jul'11 - 103 messages
  • Thailand
VIMONTA_S@hotmail.com
Had one unit with 558 code. This lift had excess voltage from the battery to the chassis of the forklift. Ended up cleaning the battery surfaces and isolating the battery with rubber mats on the bottom and sides of the battery so it would not contact the chassis. You can also use wood to insulate the battery also. Hope this helps you out.
  • Posted 31 Mar 2025 01:54
  • By mwjski
  • joined 26 Jan'18 - 33 messages
  • Montana, United States
Do you managed to fix it and how?
  • Posted 11 Mar 2025 04:04
  • By stef_g
  • joined 25 May'19 - 12 messages
  • Greece
Hi Igor
I got the same problem with my Nissan k1b1 it also showing 558 communication problem. Did you came right with your our is there anyone that can help.
Much appreciated.
Albano
My email address [email address removed]
  • Posted 21 Mar 2017 21:31
  • Modified 21 Mar 2017 21:32 by poster
  • By albano_d
  • joined 21 Mar'17 - 2 messages
  • Gauteng, South Africa
