Mitsubishi help code 31
Hey everyone, kinda stuck here. I have a Mitsubishi 2FBC18 serial A2BC1-60157 that has error code 31 on startup. I can hear the line contactor pull closed and the immediately open again, then the core 31 comes up. Any help would be awesome, what is this code for? Pump contactor? Control card?
  • Posted 7 Sep 2016 02:19
  • By Coolguy1
  • joined 7 Sep'16 - 2 messages
coolguy,
you question about this code was answered here:
ht tp://www.forkliftaction.com/forum/discussion_20826.htm
remove the space i added to the http to go to that thread
  • Posted 8 Sep 2016 14:09
Coolguy1. This is an old truck, code 31 is failure in the pump driver board logic. check all the diodes and transistors in the pump system if nothing found it could be your logic or driver board for the pump.
  • Posted 8 Sep 2016 00:27
  • By Support
  • joined 17 Aug'16 - 35 messages
  • West Mids, United Kingdom
Toyota 02-2TD20
SMV (Konecranes) 12-1200B
Lift Tek Elecar
