mitsubishi eop 15 forks wont go up or down
the forks wont go up or down with switch, but i can engage solinois by hand and they will go up, down switch on controler works. got fault code 01 on dispaly.
  • Posted 20 Dec 2012 11:05
  • By polecatizzy
  • joined 19 Dec'12 - 9 messages
  • Indiana, United States
should always start with the basics first - - make certain the battery is holding a full charge - don't ASSUME it is good. Verify if the the battery connector halves (and charger connector) are cracked & making full contact or are pitted (can cause high amp draw & low voltage delivery) and battery cables are in good shape - R & R as necessary, then do the foot switch wire harness thing..
  • Posted 21 Dec 2012 12:02
  • Modified 21 Dec 2012 21:35 by poster
  • By johnr_j
"Have An Exceptional Day!"
check your footswitch and wiring running to it
  • Posted 20 Dec 2012 22:54
  • Modified 20 Dec 2012 22:59 by poster
Muncie, IN, United States
Bolzoni SpA (Group HQ)
