Milky oil. FGC 15 3000 lb
Hello.
I am hoping someone can point me in the right direction...
I have an older Toyota FGC 15. I don't know the year (probably early 80's or mid to late 70's).
It has a 5r 4 cylinder propane engine.
The problem is fluid in the oil after about 15-30 hours after each oil change. I had the head gasket changed last year as my mechanic assured me that that was the culprit. Apparently not.
I change the oil after it turns milky (usually around 20 hours of use)
. The problem keeps reappearing. I use 15/40 oil.
After the head gasket was replaced and I saw that the problem remained, I bought a new regulator and put it on- which did not solve the problem.
Recently, I sent the oil away for analysis. No antifreeze was present.
I would greatly appreciate any advice given. I am at a loss.
Thank you
Jim
[email address removed]
  • Posted 2 Feb 2018 02:06
  • By Jamkit
  • joined 19 Oct'15 - 9 messages
Also, the breathable oil fill cap he fabricated has not worked apparently.
  • Posted 2 Feb 2018 03:33
  • By Jamkit
Thanks for the reply.
A friend of mine (a lot better mechanic than I) was thinking along those lines too I guess. He fabricated a oil fill cap that "breathes) by
Cutting out the cap and added a piece of porous material in hopes that the engine just needs to breathe more. There is no pvc.
And yes, normally the lift runs for short periods of time almost every day ( around 15 minutes or so)...
Thanks again
  • Posted 2 Feb 2018 03:03
  • By Jamkit
Hopefully Brewski is correct. I have an older version of your forklift. Had the old 5R head gasket fail a months ago, replaced it myself, all good on my side to date (knocking on wood).
  • Posted 2 Feb 2018 02:49
  • By Jetty
  • joined 12 Mar'17 - 44 messages
www.BacliffRV.com/Toyota_Forklift
Does this truck have a PCV valve? If it does you need to change it. Are you running the truck for short periods of time? Like 5 minutes and then shutting it off?
  • Posted 2 Feb 2018 02:39
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
Still GX10
Still GX10 2000
Poland
EUR950
UN Forklift FBR25NQC3
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
edition #1293 - 6 August 2026
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
