MAX TRAVEL SPEED ADJUSTMENT
How do I go in to adjust the max travel speed?
Thanks
  • Posted 23 May 2018 22:59
  • By troy_m
A-Lift Services -- safe -reliable -affordable
If the truck does not have the deluxe dash, you will need to call in the Toyota dealer. It requires the software and connection hardware same as the larger Toyota trucks to adjust the speed.
This only applies to trucks built after April of 2016.
  • Posted 24 May 2018 22:21
  • By ramon_m
  • joined 30 May'14 - 42 messages
Libiao Robotics
